92 bongo stalling
myd1rx7, Jan 1, 11:42am
cant seem to find whats going on here. ive searched for a vac leck, but cant find anything, have turn the timing up a bit to help, but whenever i use the gears to slow down it seems to stall just as im about to stop! but if i but her in neutral and slow down it seems to work, but rember i have turned the timing up a bit so she revs a wee bit higher now. any idears on what to look at!
pettal, Jan 1, 12:00pm
fuel filter !.
jmma, Jan 1, 12:02pm
Clutch need adjusting/bleeding! Does it try to go forward if you start it in gear with your foot on the clutch!
myd1rx7, Jan 1, 12:42pm
clutch is all good. she is also alot more smoky on start up than use to be. all this has only just started this week. bout to have a look at fuel filter.
budgel, Jan 1, 2:15pm
I am assuming petrol engine, check the solenoid on the carb; point gap if it has points.
myd1rx7, Jan 1, 2:24pm
yep petrol, doent have points, will check the solenoid on the carb, just heading down road to get fuel fliter oil fillter as well.
myd1rx7, Jan 1, 3:43pm
change the fuel filter n oil filter, still smoky, (white) and still stalling
NZTools, Jan 1, 3:51pm
Check the little dash-pot on the carb that lifts the idle for the air=con etc. If it is poorly adjusted, or not working, it can cause your problems.
jmma, Jan 1, 3:51pm
Try disconnecting your brake booster hose and blocking it off, may be a leak in there, check your brake fluid also.
myd1rx7, Jan 1, 6:40pm
jmma, how does the brake booster effect the running of the van! im just not folling you thats all. thanks
myd1rx7, Jan 1, 6:41pm
oh yea the van is really smoky to. white smoke
pettal, Jan 1, 6:46pm
White smoke = burning brake fluid .
myd1rx7, Jan 1, 6:53pm
thanks for that pettal :) i will get back into it in the moring. what bout antifreez! can this do the same! ive notice its got a leak somwhere.
pettal, Jan 1, 6:57pm
White smoke or is it steam !.
myd1rx7, Jan 1, 7:04pm
looks to be smoke to me, has a fant blue in it also
jmma, Jan 1, 7:13pm
Uumm, thats a different story now (o: How much coolant are you leaking! Might pay to do a compression test.
myd1rx7, Aug 1, 8:49pm
i will let you know in the morning jmma, havnt found the leak yet. looks like just driping when runing at the mo, not to much though.pain to as shops are shut mon/tuesday. and im ment to be going away wednesday
