Laws regarding partially stripped interior
siren676, Feb 14, 8:54pm
Im planning to go to the next round of nightspeed and want to remove some of the interior to save weight.
Im wanting to remove the rear seats, the spare wheel and a few more parts in the rear. This will all be put back in the next day
What can and cant i remove!
foxdonut, Feb 14, 11:28pm
Its probably class dependent! Don't they have a spec sheet or requirements and rules document!
As a rule of thumb, unless it says you can't you can't do something then you can. Smokey Yunick springs to mind.
siren676, Feb 15, 6:53am
I was meaning what i can remove and still be allowed to drive to the track.
It seems that im allowed to remove the rear seats but i have to take out the seatbelts as well.
mrfxit, Feb 15, 6:56am
Cavity holes in the front doors /footwells etc MUST be covered for road usage.
Don't think it matters behind the front seats as long as theres no passengers.
Just flip the seats out at the track
project.d, Feb 15, 7:43am
you are aloud to take the back seat out aslong as you take out the seatbelts aswell then its classes as a 2 seater
siren676, Feb 15, 7:52am
I have been told that the door cards must stay but anything else is alright for removal just as long as no-one can be seated/restrained when the seat is removed. Taking the seats out at the track isnt an option as all my mates are busy and i would have nowhere to put them.
siren676, Feb 15, 7:53am
Itll just look funny since its a 5dr
twink19, Feb 15, 9:36am
do you think that the few kgs will make a any difference
johnf_456, Feb 15, 9:40am
vs the time putting it all back in.
gunhand, Feb 15, 9:50am
Removing interior will save you bugger all unless your needing nano seconds to win.
you will rarely green light the same each time so there goes any savings unless you are a profecint drag racer and have the same reaction times.
A spinning wheel, wind, track and so fourth all slow you down or speed you up and can be also different each time. Unless your removing huge weight I wouldnt bother.
smac, Feb 15, 10:59am
Don't under estimate the difference weight loss can make.however in most saloons you'd need to start swapping glass and/or panels and battery to get a measurable difference. If you got really serious on a 1000kg car you may be able to shed 50kg, and that's worth it. But you're talking side windows etc.
Lightened fly will save more, faster.
johnf_456, Feb 15, 11:22am
Yip large weight difference do, but small things marginal.
siren676, Feb 15, 11:32am
The car is supposedly 950kg from factory and i plan to make it as light at possible to get a good time and to beat a friends time.
I used to have a sub in it but removed it and the car now accelerates alot faster.
smac, Feb 15, 11:34am
That was because of the removed wank factor, not the weight.
johnf_456, Feb 15, 11:34am
What sort of car is it! Must be gutless for such a small weight change to make a difference.
1fordluva, Feb 15, 11:35am
Must have been a freaking large sub to notice it accelorating quicker.
What do you wiegh!
Maybe you should shed some before stripping out the car.
Just a suggestion
siren676, Feb 15, 11:39am
Its an ep91 starlet only has 72hp(proven) so removing weight does wonders.
As to how much i weigh. Just weighed myself and im only 60kg
siren676, Feb 15, 11:41am
Had to remove it as the amp f#%ked out
socram, Feb 15, 2:37pm
Just make sure you take a dump before you run.
I would have thought that for what you are doing, perfect tyre pressures (maybe slightly smaller driven wheels even), and sharp reaction times would be of far more benefit than stuffing around with the seats.
Look, to be honest, a car is what it is and you can't realistically compare different makes, if they are different capacities, state of tune, gear and final drive ratios etc., on what I presume is just a straight drag!
Twink's smaller engined Escort will always beat my 3 litre GT, as we are not comparing apples with apples.
siren676, Feb 15, 4:15pm
I run in dyo class (staggered start) so im just there to have fun and try to get the best time i can
johnf_456, Feb 15, 4:59pm
Subs are not all a wank factor, better ban subs. Subs will improve your music experience if done right.
siren676, Feb 15, 9:04pm
I know its about consistency but i want to try to get the best time i can with this engine. Im just trying to make it into the 17's
mgmad, Feb 16, 7:34am
Losing weight is the cheapest hp gain you'll get. Example - MG Metro, 810kgs factory, 72hp standard - 88.9 hp/tonne. Front seats weigh 15kgs each, rear seats ~20kg combined. Spare wheel/jack ~15kg. Remove passengers seat, rear seats and spare wheel/jack I save ~50 kg. Now have 94.7 hp/tonne. Big difference for 10 minutes work (and 10 mintues at the end of the day, of course). I've done this many times at the track and at hillclimbs and left seats on the side of the road/pits under a tarp.
Given the quoted numbers for your starlet, you would get an increase of just over 4 hp/tonne by losing 50kg which is more than doable by removing seats and spare.
Beyond that though there is less return for the effort - carpet (more particularly underlay) is probably the next best gain for a given time. Door cards etc are hardly worth it on a road car.
siren676, Feb 16, 8:58pm
Dont think ill go as far as removing the passenger seat.Door cards are required to pass the inspection at the track and i think they are required for road use.
Cheers for the positive advice.
siren676, Feb 19, 5:22pm
Cheers guys.
I took out all the stuff in the rear and i think it helped my times.
I managed to do a 17.6@123kph and got 3rd in dyo. :) Didnt do a single 18sec pass which is better than last time.
