maybe the jachting supply ! i seen some cubes for 800$ for jachts
sorbus,
Feb 18, 3:54pm
i shall look thanks
greghale,
Feb 18, 4:23pm
solar showers work great.$10 from the warehouse. If you want a house shower you will need a Good pump $300 a good battery $250.Gas califont$500 Plumbing $200. be4 you even start with the cost of the shower. Then you need holding tanks for grey water and fresh water. All up best part of $2500.
greghale,
Feb 18, 4:24pm
makes the ware house shower look good A!
sorbus,
Feb 18, 4:44pm
yes it does for now
thejazzpianoma,
Feb 18, 5:14pm
If you don't mind showering when the engine is warm you can use a system that runs off the engines cooling system for a fraction of that, and every bit as good so long as the engine is warm and running.
thejazzpianoma,
Feb 18, 5:19pm
If you want to go cheaper again for about $40 you can get an electric 12v shower, you just boil the jug, throw that in a bucket with some cold water and drop the feeder hose in. You can also use one of those to make your own version of the commercial one described above.
greghale,
Feb 18, 5:19pm
yep a heat exchange people on boats use it.Works well But still costs Big bucks
greghale,
Feb 18, 5:23pm
Yep i have used one of them too.They work well.You can pump out of your solar shower bag too.
thejazzpianoma,
Feb 18, 5:29pm
No, not expensive I have seen complete units for a few hundred dollars.
Heres the first one from google, have seen other brands here in past for a bit less than that in NZD (Just under $400 NZ). Of course, you can always make your own too.
chito,
Feb 18, 5:32pm
Heat up the water and put it in a pump up garden sprayer.
petermcg,
Feb 18, 8:36pm
why not just pick up a small fiberglass shower from your local plumbing shop
greghale,
Feb 18, 8:56pm
petermcg Have you not read the thread!/!
petermcg,
Feb 19, 9:08am
Yes Greg I did read the thread. I just read it again slowly, in case someone had already suggested that, but no!When I build motorhomes I use kitset kitchen modules from placemakers and fiberglass shower enclosures from plumbing world, the 750 x 900 works a treat and can be purchased as a two peice item, so you can actually get it in through the door of the motorhome, you might also need a toilet, but hang on Ill go read it again first.
Feb 19, 9:13am
maybe his mobile home is tini!
les37,
Feb 19, 9:46am
rv custom interiors
bigfatmat1,
Feb 19, 12:31pm
how do you know greg they do not just want a replacement shower! they might already have the rest.
sorbus,
Feb 21, 7:32pm
yes jist want shower
sorbus,
Feb 21, 7:35pm
off to placemakers
greghale,
Feb 21, 7:39pm
well there you go.Once again only getting half the story and jumping to conclusions .llol In that case I say build your own to fit the space.
muzz67,
Feb 21, 7:46pm
what the hell does OP want! The cabinet, the mixer,, what!
greghale,
May 12, 6:15am
and maybe because they said that.
