Whats up with my coon!
spotx101, Feb 23, 1:57pm
Every now and then wont start without a jump, gel cell in battery glowing green az, power steering has gone hard on me a couple times at slow speeds as well as engine almost stalling and then revving when park manouvring.
johnf_456, Feb 23, 2:12pm
Weak battery, have you got a multi meter handy! Measure the voltage across your battery while the car is running and off. A lot of auto electricians will kindly test your charging system for free.
s.patete, Feb 23, 2:17pm
What sort of coon! Ive got an el thats doing the almost stalling when ya button off accellerator and random revving when idling. Starts every time tho
gilligan2, Feb 23, 2:31pm
Lol. Is the aternator belt the same one that runs the power steering! if the belts gone west hat will explains your problem
gilligan2, Feb 23, 2:32pm
Lol. Is the aternator belt the same one that runs the power steering! if the belts gone west that will explain your problem
johnf_456, Feb 23, 3:03pm
Check the obvious, is all belts there! Look at the pulleys! Check voltage, load test battery
spotx101, May 20, 7:07pm
thanks everyone, much appreciated, will start looking into, model is an EFII by the way.
