Help me please
dakota57, Feb 25, 5:39pm
my power steering hose in my isuzu mu is leaking fluid. would it be safe to drive for another day until i can order in another hose!your thoughts appreciated Roz
twink19, Feb 25, 5:43pm
go for it, just top up fluid
intrade, Feb 25, 6:10pm
i would not risk it the pump will puke it self when it runs dry. unless its a tini leak
dakota57, Feb 25, 7:03pm
its a small split in one of the hoses,will top it up and not use till i take it to garage on mon,just in case.thanx very much for your help.
ginga4lyfe, Feb 25, 9:27pm
if its a small split, what you could do is get some rubbing alcohol on a rag, wipe clean the hose where its leaking and glue the split together with super glue, that should get you around untill you take it back into the shop :)
suplyuparts, May 26, 9:09pm
cut it an re-join it.
