Ballast resister on discovery?
roadkill3, Feb 26, 2:48pm
i've looked around the coil area then looked around engine bay for it, anyone know where to find it! problem is it won't start at the key without running wire frombattery to coil, it's a 94 L/Rover discovery 3.9 v8i
jono2912, Feb 26, 3:50pm
bigfatmat1, Feb 26, 7:26pm
It doesn't have one.
franc123, Feb 26, 7:29pm
Even if it did have a ballast resister it still wouldn't be the cause of the problem anyway, if it doesn't want to fire at all.
by_hdt, Feb 26, 9:44pm
Problem is most likely in the spider unit behind the radio, or the Immobiliser, very common for this to lose the plot. Have you got the Emergency Key Access code!, or any of the original remotes!
roadkill3, Feb 27, 9:23am
no code have sparky coming to have a look today
elect70, May 31, 1:43am
imobiliser was an option mine doesnt have it , sure ignition fuse ,auto /brake interlock ok !
