Can you use a 2 channel amp for 2 1000w subs?
jasongroves, Feb 28, 5:56pm
Yes.maybe no.
Depends on the amp and subs in question.
Whats the actual wattage (rated or RMS) on the subs and the rated output on the amp!
Makes, models will help.
Are the subs single or double voice coil!
What Ohms are the subs!
In other words.much more info is needed;)
simon081, Feb 28, 5:59pm
this is the amp iam lookng at 356586958 my subs are 1000w sonys hope this helps all i need to know is wether this amp will run them
jason18, Feb 28, 6:02pm
Looks like a good amp!
jasongroves, Feb 28, 6:03pm
Heres the actual specs for the amp (its a single channel mono block, not a 2 channel):
http://www.fusionpakistan.com/Product-Detail.php!CatId=2&SeriesId=1&ProductId=18
Yes, its capable of running several subs, but 1000w is not the actual subs rating.
Whats the model number!
Or can you find one the same on TM!
Because more info is needed to determine the best way to wire them up.
simon081, Feb 28, 6:03pm
will it run 2 subs though thats what i need to know
jasongroves, Feb 28, 6:04pm
And its not a 5000w amp as his auction says, its max rated at 2500w.which means sweet f all.
True ratings:
825 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1310 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1790 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
jasongroves, Feb 28, 6:06pm
I have already answered your question.
simon081, Feb 28, 6:07pm
356136132 i have 2 of these
jasongroves, Feb 28, 6:07pm
Oh, and it will probably blow your little Sony subs to bits;)
jasongroves, Feb 28, 6:10pm
How many Ohms are they rated at!
simon081, Jun 3, 5:09pm
1000w
frequency response 25 H-z 2500 Hz
Rated Power 300w
Impedance 4 Ohm
