What do people use for undersealing a car! was thinking a good spray with black bitumen paint, or is it still possible to get proper underseal!Thanks
Feb 25, 6:22am
any paint i used some galvanise spray after welding and then use body deadener underseal. supersheep auto sell it 16 bux. galvanise sprayis 20$ from fencing places
johnf_456,
Feb 25, 6:32am
You can get under sealer in a spray can makes it very easy to apply from places like woottons car accessorys. No more trying to apply gunky tar
kenw1,
Feb 25, 2:57pm
Just got some from local paint suppliers, so going to spray it one over the next few days.Thanks to all.Hope the COF people are suitably impressed.
thejazzpianoma,
Feb 25, 3:05pm
If you have done repairs or there is any reason to suspect things might be iffy underneath the COF people might be anything but impressed, especially if it is a thick underseal type coating. If you suspect any trouble might be best to show them before spraying it on.
robertsons-nes,
Feb 25, 3:43pm
or else just spray it on and go over a dusty road whilst still tacky hahaha
richardmayes,
Feb 25, 3:52pm
I love underseal.
A thick, semi-waterproof (especially once it dries out and starts to crack up a bit) blanket just right for trapping water and mud against the underside of your wheel arches and your boot floor, so that rust may flourish there!
Drop in a British engine and gearbox, the steady release of oil from all the seals will soon coat your chassis in the best corrosion treatment of them all.
kenw1,
Feb 26, 6:08am
They actually suggested that I needed to get some underbody protection on it last time.All is perfect, but would like it to remain so.Its a Mitsi Canter Motor Home, so no oil leaks.Will also inject all the voids with fish oil as well.
robertsons-nes,
Feb 26, 7:20am
for the fish oil i would reccomend wurth body wax does not go hard and flake a problem you might have also with a lot of underseals as richard has said they will harden over time and crackmaking perfect areas for rust to start and go unnoticed for years until it becomes a problem
steelman3,
Mar 2, 2:30am
Drop in a British engine and gearbox, the steady release of oil from all the seals will soon coat your chassis in the best corrosion treatment of them all.[/quote] your right mate I got a jag like that factory corrosion protection system it works brillantly
johnf_456,
Jun 5, 8:14am
So true, just remember to top the oil daily before you drive.
