LDV Convoy ambulance
wellyguynz, Jan 11, 7:37pm
My mate just brought a 1998 LDV Convoy wioth a3.5l v8 Rovor engine, i know its a big van but is there any thing we can do to get a bit more from the Motor !
mram, Jan 12, 12:56pm
Yep there sure is!
Some Options:
*Replace the cam with a stage 1 from auckland cam services(old 3.5 one likely worn by now as they do)
*Source a 3.9 rover with fuel injection
*Find a dirty old leyland p76 to drop in!
If you just want a bit more out of the 3.5 you have,consider a proper four barrell manifold like a harcourt or willpower and a edelbrock/weber 500 carb, you will hardly believe the difference if you have the restrictive S.U carbs
by_hdt, Jan 12, 4:03pm
Buy a wrecked LP range rover and swap the 4.6 into the Van. The last of the 4.6's made good power.
stacie_nz, Jan 12, 6:44pm
that dont have carbs . injection
mram, Jan 12, 8:01pm
OK yeah 1998 I guess it would have injection,lol. The 4.6 would be the go however the 3.9 didnt have the problems with the liners that the 4.6 had. those 3.5's came in two compression ratios 8:35:1! and 9:35:1,I think most of those vans had the lower compression motor. Rovers/Buick v8's are expensive to get power out of,my offroader runs a p76 4.4,but I think Il ditch it when I want more power and go something like a 302w,not a heap heavier and more power
wellyguynz, Jan 13, 10:07am
Sorry mate it has a rover engine with twin Su carbs at the moment
the_don_61, Jan 13, 10:13am
Take tops off the carbs and lift the needle 0.5 - 1mm.
and you will probley have to ajust the idle
That will allow more fuel.
owene, Jan 13, 11:52am
Biff it and replace with SB350 and a TH400 box. Woooosh!
elect70, Sep 12, 11:41pm
Go to the Aussielandrover forums, heap on thereon hot up & conversions .
