My damned aprilia rs250 wont function properly. I need some one to tell me how to set up the power valves properly! I have the marks on the pulley and bracket all lined up where they should be but its still not right but if i adjust it out either side the power loss varies across the rpm range.
I have a full workshop manual. Have followed the instructions to the letter but it just doesn't want to rev any higher than 10,000rpm once you get into 3rd gear. Its as though the valves just aren't opening at full rpms.
gilligan2,
Mar 2, 1:13pm
you musta be a kiwi, no!!.[/quote]
Slovak
irenew,
Mar 2, 1:13pm
Italian Papa.not Polynesian. Get the accent right!
gilligan2,
Mar 2, 1:20pm
That link was help full
gilligan2,
Mar 2, 1:52pm
I pulled it apart but cant seem to get my head around whats going on with it in relation to the illustration provided in that link.
budgel,
Mar 2, 1:55pm
There is another link within that link, have a look at that.
afer_daily,
Mar 2, 2:37pm
Another link !Lance Link secret chimp !
gilligan2,
Mar 2, 3:33pm
kazbanz wrote: gilligan--pull your zorsts off. It'll be a truck load easier to work it out when you actually see whats happening in there. Personally I do power valves by feel. Anything else loses relivance as stuff wears. Full out is for low throttle . Half is for half throttle and flush isfull throttle.
Yup its all sorted now. the spring on the inner pulley wasnt set up right causing the valves to close at hi rpm on the upper cylinder
gilligan2,
Mar 2, 7:02pm
Now i cant seem to get the cooling system to bleed up.
trogedon,
Jun 9, 2:40am
Don't worry Rik my wife (!) was having you on!
