Rb25de blowing whiteish blue smoke
tarshao, Jan 12, 10:36am
i have just done a full head gasket etc with the head machined after car had a blown head gasket but now the car blows smoke when it revs could this be a timing issue! the motor never smoked before pulling it apart!
ginga4lyfe, Jan 12, 10:56am
how long did the engine sit open after you whipped the head off! My guess is that you got a little bit of rust on the cylinder bored and maybe that caused it to poke the rings! and no timing cannot be the issue, its either as i have said, or you haven't torqued the head down properly
tarshao, Jan 12, 10:57am
about a month but it was coverd the whole time
jsbike, Jan 12, 11:01am
how long have you run it for! after having an rb25det engine sitting on its side for 2 years then installingin a car, it smoked for a couple of days
tarshao, Jan 12, 11:13am
ive driven roughly 60kms it doesnt get better or worse
mugenb20b, Jan 12, 11:37am
What colour is the smoke! Edit: Never mind, just read the title.
mugenb20b, Jan 12, 11:39am
Does it start easily when hot and cold! Not missfiring!
cypherboy, Jan 12, 11:59am
Compression test!
thunderbolt, Jan 12, 12:38pm
Did not smoke before you did the head gasket! Or did not smoke before it was overheated which caused the head gasket to blow originally!
tarshao, Jan 12, 2:48pm
did not smoke before the car blew the gasket up untill i put it back together startd it upand now it smokes.
tarshao, Jan 12, 2:50pm
with a compression test will this show wheter it is the rings or a faulty valve guide as 1 guide never got replaced as we could not get it out!
tarshao, Jan 12, 2:52pm
starts perfectly finealthough i put it neutral at a intersection the other day it stalled
thunderbolt, Jan 12, 2:55pm
Maybe it got hot enough for the rings to lose tension!
tarshao, Jan 12, 3:07pm
possibly although i started the car after the car had overheated after putting more coolant in the radiator but now it smokes a white/grey smoke with a faint blue tinge
frank1, Sep 9, 1:56pm
To eliminate ring prob,hold foot about 1/2 throttle on accelerator for a few mins ,if blue smoke stops.not a ring prob.
If still smokes,valve seal prob,were the seals replaced!
