Whats the easiest way to get 200kw out of one of these! Does it need to be forged etc! Or Jus a bigger turbo, injectors and what not! What have other people done that works long term!
falcon15,
Jan 13, 10:45am
200kw is quiet a easy target for these engines. The most reliable way would be to upgrade the turbo, exhaust, intercooler, fuel system and get a aftermarket ecu and a decent tune to run it all
1ollie,
Jan 16, 12:28am
If its in good condition 200kw should be pretty easy. If on a tighter budget I would get either a S15 Silvia or N14 GTI-R Pulsar T28 turbo(bolts onto the factory manifold), a 3" exhaust, decent front mount intercooler & mandrel piping, decent blow off valve, 550cc S4 RX7/444cc R32 GTR or N14 GTI-R/560cc EVO 5-9 injectors, a Link G4 ECU and of course most importantaly a good tune but if you have a little more cash to burn I would go with a Garrett GT28 turbo, a Tial 38mm external wastegate, Sinco exhaust manifold, 600cc sard injectors and that will give you much more useable reliable power but remember anything over about 160wkw you will need a decent clutch aswell.
sebatrons13,
Sep 24, 5:41am
Thanks bud
