80 series cruiser 1991 - rim offset, HDT
andya, Mar 4, 7:13pm
Hi i have a set of R15 white spoke rims that fit fine -i determined the offset (measured from inside to centre to be 90mm, I also have for a spare R15 x7 JJ ( 10) CU Rim, genuiine toyota, it fits as well and has a offet of 110 mm
My question is would genuine toyota R16 rims fit ok ! where can i find online the offset of the factory fitted rims
robbos1, Mar 4, 7:31pm
If the rims are off a solid axle type front end (ie cruiser, 106 hilux, safari etc), then they should be ok. as opposed to an independant front end (130 surf, pajero, terrano,etc).
Failing that put them on and test them.either they will work or they wont!
zephyrheaven, Mar 5, 12:34pm
depends what year your cruiser was assembled, early ones ok but late 91 went to bigger brakes hence 16" wheels
andya, Mar 5, 6:46pm
Cheers Zephyr, so 15" fit fine then fair to assume the 16 might ! its the offset that concerns me still , had nightmare with holden rims once -
, thanks Robbos, thats a great idea - i'll just get a rim sent down by the seller and try it out .and send them back if they don't fit .
zephyrheaven, Jun 17, 11:52pm
Weird , I just got my VX from Wanaka - must be a few down there
Try & get black 16X8's from ROH or similar they are sweet & have a nice dished offset giving it a wider track
What size tyres are you going to run! I was looking at 315/75/16 but will stick to 305's I think - had 33's on the last one & it gobbled up 'off the mark' performance
