had the injectors done , still smokes heaps black smoke . what next
Mar 4, 5:19pm
possibel pump damage have you never added any additive to the diesel!
robertsons-nes,
Mar 4, 7:48pm
get in touch with graham at easy driver cars in manukau hes got a mint diesel mechanic,he was having heaps of problems with a safari and tried heaps of guys to fix it and finally found a real good young fella down south aucks
mechnificent,
Mar 4, 7:55pm
Compression, fuel atomisation, pump settings.
You've done the atomisation, next (and cheap) thing is do a compression test.
keith18,
Mar 4, 8:16pm
runs well ,starts well ,does 150km ok just dies under load (wouldnt pull a hen of its nest) belches out black smoke with any load on it .
mechnificent,
Mar 4, 8:20pm
Well they will do that if the compression is down or the intake is blocked. Some may have a filter on the exhaust too. carbon filter they are, meant to be changed every so often. Cheapest thing though is to do a compression test first I reckon.
keith18,
Mar 5, 8:09am
taken air filter out
Mar 5, 8:25am
we still dont know what year it is and if its efi or upgight pump like the 80s model had.
Mar 5, 8:27am
if its got egr you rip the intake off and clean its ports and remove the crap. but be carfull if it is electronic crap it likely will throw then a check-engine light. loads things it could be untill we know what yearengine-number and what injector pump.
keith18,
Jun 17, 7:57pm
its a 1989 4.2 non turbo
