18rgeu
phatcorona69, Jan 14, 4:43pm
18rgeu efi
so i have just done an engine conversion in my corona,went from an 18r to twin can efi
was wondering if anyone knew what the square plug is by the airflow sensor!
in the car motor was taking out of it ran into the drivers side of the firewall.
car has been wired up starts but is over fueling,from what i have found on the net
it could possibly be air flow sensor not wired up right but am also wondering if this plug not being wired up could also be my problem any help would be great thanks
vtecnet, Jan 14, 5:27pm
Hmmm, I remember these engines, my 1982 Corona GT coupe had one, disconnect the air flow sensor and see if it runs about the same as now! is it using the correct ECU!
phatcorona69, Sep 17, 9:49am
will give that a go
and yes its running the ecu from the motor
