I have one of these with a J13 engine, I would like to put a 1500 in it. are the A series engines newer!
pge,
Jan 14, 8:05pm
Back in the early '70's, I had a P410, and fitted a BMC 'B' series from an Austin A60.
Despite rumours, the BMC head did NOT drop straight on the P410 block, the engine mounts were on different angles, and I used the A60 floorchange box, but had to build a new trans crossmember.
It absolutely transformed the wee beast.
The P411 was an adaptation of the "B" series motor, but the engineering internally was far superior.
I would not recommend the use of an "A"series motor,
I would suggest you source a later-model, pushrod Datsun engine, preferably with gearbox, and adapt that.
Good luck with your project, they are an unusual wee car.
the_don_61,
Jan 15, 6:06pm
Dont quote me but. J engine is a Prince engine.A series is Nissan. Datsun clubs in the USA for P411is it a SSS!.
