Would a coil pack cause intermittent missing?
friendly_prawn, Jan 15, 7:36am
car (my listing) has struck a small hiccup. yesterday started to miss then it came right again. It has done it a couple of times in the past. Ages ago. Lose wire! coil pack!
do you think it will sell as is or fix the heap first! And how do you fix or diagnose if the issue isnt present at the time! Any thoughts please!
alan1111, Jan 15, 7:38am
What sort of vehicle we talking about.
Could be any nos of issues besides coil packs.
friendly_prawn, Jan 15, 7:42am
1999 nissan cefiro. 2L A33
mrgts4, Jan 15, 8:21am
Could possably be a coil pack. I had a nz new maxima with the same problem and was the coil pack. Was a real pain as it was intermittent and could go weeks without doing it.
bigracket, Jan 15, 9:11am
My money is def on the coil pack, they do exactly that when fecked.
richard198, Jan 15, 9:31am
I had an issue recently with intermittent missing.
In this case, it was a damaged HT lead.
(It could just as easily be the sender unit (pulse coil/trigger etc.) as well as the coil or leads.)
bubbles244, Jan 15, 9:51am
ignitor pack
bitchwitattitud, Jan 15, 9:58am
A33s dont have ignitor packs, its ecu controlled. I would be looking at coilpacks or possibly airflow meter.
friendly_prawn, Jan 15, 11:37am
would any one know a rough estimate to fix if it was a coil pack!
Local shop says $115 to test and $450 just for coil pack with labour on top. Ouch.
ozz1, Jan 15, 11:44am
a33. normaly one of the rearcoil packs. tryroscoes in ashburton. for one. or niscars in wellington. a little bit hard to get to. but you could do it yourself.
friendly_prawn, Jan 15, 12:27pm
problem is knowing which one to replace. especiallywhen the car is running fine.
also need proper diagnostic computer.
not quite so simple unfortunately.
bigfatmat1, Jan 15, 1:11pm
I think you find the igniter is built into the coil packs. They can be tested when working with a scope you should be able to determine which coil pack is at fault. By the primary voltage. I would recommend a reputable Auto Electrician.
friendly_prawn, Jan 15, 1:26pm
thanks bigfatmat.
Sounds like a really good idea.
Although i might not have too bother. After the prolem occured, I dropped the price heapsand now I seem to be getting lots of emails so it may just sell as is. Fingers crossed, otherwise I'll follow up on your option and phone an auto elecrician. Could be a much more sensible option.
cheers mate.
kiwis0, Jan 15, 1:34pm
Buy one yourself, it only connects to one lead, they are $15.00 to buy maybe $30
450 for a coil, Ithink they are coiling you.
friendly_prawn, Jan 15, 2:36pm
where would you buy a coil from for that sort of money!
kiwis0, Jan 15, 2:45pm
I Use to get them from a auto parts shop, but I haven't brought one in 15 years .
jason18, Jan 15, 3:20pm
Ficher and Paykal doesnt have a coil pack!
fordcrzy, Jan 15, 5:34pm
Make sure you in and clean all your earths on the car as bad earths on the engine cause the coil voltages to sky rocket and they fail
friendly_prawn, Sep 21, 1:40pm
soldddddddddddddddd
dropped the price lowwith the explanation of what had happend,
And voila. Gone same afternoon.
cheers for all the advice guys.
