Best thing for removing pesky stickers?
4ageturbo, Jan 15, 7:51am
hi there, i am removing one of those front anti stone chip stickers that looks horrible.whats the best thing to use so i dont damage the paint underneath!ive already got rid of most of it with a heat gun. just need to get rid of the last residue.
is meths safe to use!
donz01, Jan 15, 8:02am
de solve it is brilliant. I have used it a lot and its available at most supermarkets and mitre 10 etc.
bashfulbro, Jan 15, 8:10am
Turps, is excellent, i have tried all sorts, but finds turps is the answer.
4ageturbo, Jan 15, 8:18am
clear coat safe!
richynuts, Jan 15, 10:33am
Petrol works possibly the best, I tried heaps of different products and petrol was still the best, I went into a sign writers not so long ago and petrol was what they were using to remove old grapics also, they said the same.petrol is the best, just don't know how they would get on if OSH showed up!
aragorn2003, Jan 15, 10:37am
thats some expensive sticker removal lol . we use ados solvent which probably isn't any cheaper
donz01, Jan 15, 10:45am
Its safe on clearcoat. It can be used on most surfaces with out any problems. It may be citrus based from memory.
henderson_guy, Jan 15, 11:36am
Yes, Desolv-it is citrus based and can be used on most surfaces safely. Ados solvent-N - ~$15 per litre so petrol is definitely cheaper than that! Meths is good too, should take any adhesive residue off and won't damage your paint.
detroitauto, Jan 15, 1:31pm
Prepsol
bellky, Jan 15, 1:34pm
i've found meths useless.
terps is ok, petrol the best
johnf_456, Jan 15, 2:24pm
petrol works brillant
cpnnz, Jan 15, 2:42pm
Wax & Grease remover from Supercheap was good.
spacies_nz, Jan 15, 3:37pm
I remove stickers quite a lot and found CRC Peel Off Label Remover to be the best. Better than DeSolvit.
I wouldn't bother with anything else.
soph001, Jan 15, 5:15pm
I use WD40. Spray it on, wait a few minutes to work it's magic.
joanie32, Jan 15, 5:34pm
AKA prepsol. All I ever used and I used it a lot.
lookoutas, Jan 15, 6:19pm
Took some off only last Fri, using "Wax & Grease" to get the glue off.
Doubled over a soaked rag and lay it over the glue, then dribbled some more W&G over the rag, and 'walked away'
Came back after about 5 minutes, moved the rag along to repeat the process, and scraped the crap off with a plastic spatchula.
A final clean off with a fresh rag, and it's all good.
m16d, Jan 15, 7:49pm
Petrol.
singing1, Jan 15, 9:08pm
I have found that petrol does soften the glue but wont remove it while diesel will take that sticky backing off your panels.
4ageturbo, Sep 23, 1:18am
tried De solve it and it was too weak,
meths was better but still abit weak.
maybe will try that crc label remover as i have some at work :)
