DA7 ZC Integra Inner CV
daniel1987, Mar 3, 12:26am
1989 DA7 Integra ZXi 1600 SOHC Manual, After Passengers side inner cv/shaft
Its sh*t itself, got told to look for complete Passengers driveline set up, help
daniel1987, Mar 3, 12:27am
correction: got told to look for complete Passengers side driveline set up, help
pollymay, Mar 3, 1:00am
Pick a part. ZC parts are a dime a dozen anyway. If it's only the end bit you can knock that off the spline on the passenger shaft and swap onto yours. Pretty sure you can, just a circlip holds them on usually. Could be wrong but that is how most CV setups are. Is your spline damaged! Do they use the tulip or ball and cage type! and finally does the gearbox stub/housing coming out of the box have damage! Been a while since I had a ZC but I seem to think it was a tulip type CV and they were easy enough to service once you got them out of the housing.
ct9a, Mar 3, 6:17am
i have approx 3 zc axles from a ef7 at home.
daniel1987, Mar 3, 9:49am
Including the shaft that bolts to the back of the engine!
daniel1987, Mar 3, 9:50am
Got told its way easier to swap out whole passengers driveline
ct9a, Mar 3, 1:37pm
i will have a look on saturday for you,do you no how many green bands are painted on axle!
daniel1987, Mar 3, 2:38pm
gonna get under it tonight an have a look, will let you know cheers
ct9a, Mar 3, 3:20pm
no worries, i have dc2,da6,ef7 and ef9 all in a box
daniel1987, Mar 3, 8:09pm
can only make out one green line approx 7-10mm wide
daniel1987, Mar 5, 2:32pm
double bump
daniel1987, Mar 5, 9:05pm
and bump again
ct9a, Jun 28, 12:49pm
il be digging these out tonight and will list an auction
