What kind of glue should i use
cameocooper, Jan 18, 12:04pm
I have ford mondeo, and the rear view miiror has come unstuck from the widscreen, what can I use to glue or attach it back to the black thing on the window,
have tried super glus, some kind of black putty stuff, but it still falls off
net_oz, Jan 18, 12:07pm
All of them will fall off because you want it to stick.
yeahm8, Jan 18, 12:10pm
Try double sided tape for automative use.not the paper use stuff!
tmenz, Jan 18, 12:14pm
You can buy a glue kit for this purpose from Repco, Supercheap etc.
a18a, Jan 18, 12:26pm
I know it's not the same situation, but I used liquid nails to hold louvers to the rear windscreen on my car. It's working a lot better than all the kinds of double sided tape I tried before.
patiki1, Jan 18, 12:54pm
I would try some two part epoxy on it.
wfl1, Jan 18, 1:05pm
One of the strongest epoxy glues I have used is epiglass epiglue . Not cheap but strong glue.
rovercitroen, Jan 18, 2:18pm
I tried gluing my mirror with a two part glue that was meant to be the "best for the job". I prepared the surfaces correctly and it lasted less than a week before it fell off again. So. I took the car to Smith and Smith Glass. For $25 they glued it back on with their "special" glue. Seems OK now. And if it falls off again I'll take it back to S & S and they will redo it for free.
flybye_in_a_rx7, Jan 18, 2:24pm
s&s sounds like a good idea
foxdonut, Jan 18, 2:36pm
"Black Putty stuff" is Bostick. Did you knead the grey compound into the black first! Bostick sticks Water to teflon to glass, so if that didn't work then you might have done it wrong.
2 stage epoxy should do the job.
m16d, Oct 1, 9:03am
Clean both sides with meths 1st.
