Keford cams272
snowballs4, Jan 18, 5:04pm
would i need to run a aftermarket computer to run aftermarket cams! or would a mines ecu run it, its for a 25det. Thanks
bubbles244, Jan 18, 5:14pm
depends on the ecu. is it fully reprogrammable! or was it designed specifically for the mods mines made to the engine.
the only truly fully reprogrammable ecu i have found in a grey import from japan was a 1993 R32 Rb30de.
sw20, Jan 18, 5:15pm
It depends on the car and how wild the cams are. Many AFM equipped cars can run aftermarket cams on stock ecu's.
Do you have an aftermarket turbo or other modifications to change your ve to need aftermarket cams!
snowballs4, Jan 18, 5:22pm
nope just aftermarket fuel injectors, but its tuned for no fuel cuts, speed etc,
snowballs4, Jan 18, 5:28pm
20e 20de 20dets are all reprogrammable so what i have been told, the head has been ported and polished, going for a reasonable price, i have a link g4 in the other skyline, but thats all tuned up for it,
1ollie, Jan 18, 9:09pm
In the end the answer is no you dont need one to run it and you may get a small gain somewhere but its going to make it run worse in another part of the rev range and basicly cancel out the gain! you really need to have it tuned to make use of the mods or its basicly a waste of time.
A Mines ECU is just a modified(chiped) factory ECU that is done in Japan for the engine setup on there fuel etc so will not be ideal here anyway especialy if you have changed anything.
Any Nissan RB ECU except the RB25DET VCT ones can be chipped then retuned to suit your mods but that will cost you $1000min to $2000max(better than $2500-$3500 for an after market ECU and tune) just remember no matter what anyone tells you. you CAN NOT tune a motor without using the correct gear, driving it on the road or putting it on a dyno as every motor is different and needs different tuning to make it perform to its potential.
snoopy221, Oct 3, 3:00am
Presumably it is a typo and you meant a KELFORD 272.
which presumab;y by the number IS a higher spec cam.
Perhaps being motoring and all you could supply the
overlap, duration and inlet and exhaust opening and closing and the lift
After all you
DO WANT A REPLY RELEVANT TO THE CAMSHAFT=
=SO PROVIDE THE CAMSHAFT DETAILS.
Thanks.
