Bog/ filler for dent?
kngfhrt, Jan 19, 2:08pm
have a small dent on car that i want to bog. question: ive sanded it back to bare metal do i need to use a primmer on it then bog it or bog then primmer it! theres no rust at all. thanks
richard198, Jan 19, 2:11pm
Bog it straight on to the metal.
Make sure you sand and prime the bog before it gets any moisture.
kngfhrt, Jan 19, 2:16pm
thank you richard that makes good common scents!Im glad i asked cause common scents i lack lol thanks!
lookoutas, Jan 19, 3:54pm
An etch primer is good before bog. But please yaself.
gunhand, Jan 19, 4:20pm
in this day and age you can use quality fillers over most surfaces, ie paint or primer.
You just rough up the paint and surounding area with 80 grit and 150 around the outside then fill straight over. However you will find most manufacturers still recommend taking back to bare clean metal
marcos1, Jan 19, 5:19pm
Really!Which one!
gunhand, Jan 19, 5:39pm
Thats actaully a good question! I use a few lol.Last one I actually bothered to read whats on the tin said bare metal but just had a nosey at some upol flyweight I have here at home and it says "over treated metals" so maybe I should say "some" still say bare metal. Theres that many out there its hard to keep track. In saying that when westrip a car its covered in epoxy primer and then worked over that. But one small dent isnt going to matter really as long as its clean dry and scratched up sanded correctly primed and painted.
mugenb20b, Jan 20, 10:20am
sense
kazbanz, Jan 20, 11:09am
Hi Op--just a point you might have missed. It always pays to do everything you can to reduce the size of the dent before filling-it saves a lot of work
lookoutas, Jan 20, 3:58pm
Some manufacturers don't recommend disturbing the steel surface coating, and on some makes - the bog won't stick to the steel.
dasfi, Oct 10, 6:18am
Also leaving it in primer for long periods wont be good as primer is porus and will soak up moisture
