HELPPP
skippy33, Mar 15, 8:09am
help me,have a 1995 honda oddesyy,has started missing very bad and is leaking oil from somewhere as it is burning on muffler,i know could be a number of things just hopeing its not something serious
intrade, Mar 15, 8:17am
well find the oil leak befor it goes up in flames
skippy33, Mar 15, 8:31am
not driving it untill get it sorted
intrade, Mar 15, 8:35am
sortof hope it drips oil on to your sparkplug and causes a missthat way . and not a crackedhead . as i seen plenty of these hondawith blowen engines just like toyota estima enemas.
most easy fix would be if it was a rockercovergasket leak.
skippy33, Mar 15, 9:45am
bumping fr any other ideas of wat it could be
mugenb20b, Jul 19, 7:49pm
Missfire can be caused by faulty spark plugs, dizzy cap, rotor, HT leads, or moisture or oil contamination on HT leads.Easy fix regardless of the problem. As for the oil leak, it will most likely be from the rocker cover gasket, again, easy fix. Take the car to a garage, and let them deal with it. 2.2 litre Honda engines are pretty good by the way.
