CV joints.. Anyone know how much roughly two of these cost to get replaced
finn50, Mar 16, 8:46pm
If you are in Auckland(New Lynn)call Aiden at Drive Inn.They have replaced several cv joints, cv boots & bushes on my older cars. Extremely capable, honest & well-priced.
Their business specialises in this sort of work.Good luck.
nick29, Aug 5, 8:53am
anyone know how much (roughly) two of these cost to get replaced!
intrade, Aug 5, 8:57am
depends on car
i charge 140$ for ones whereyou can buy the cv joints for 65$ like toyota caldina petrol model or some honda nissan supercheap auto stock them cheap. If its a non common car it can get expensive with the joint it self costing 250$ and a nightmareto change are citroen cv joints with there special designed clips on some 1990 models onwards
nick29, Aug 5, 9:57am
Hi intrade! Thanks so much for your help, I was quoted around $500 - $600 and I just wanted to check and see if it was a good deal :)
mugenb20b, Aug 5, 10:51am
What kind of car!
nick29, Aug 5, 11:27am
Honda Odyssey :)
ashwattau, Aug 5, 11:36am
Narrow your search for
'honda odyssey'
in Trade Me Motors
* Cars (679)
* Car parts & accessories (151)
Yep. That soundsreally uncommon to me.
hijacka, Aug 5, 12:50pm
if its outer cv then about $70-$150.if its the inner cv then about $300-$400
Edit: thats just for 1 replacement cv kit
cr4ftyg4l, Aug 5, 3:52pm
Hijacking this thread. :)
my 97 Nissan Presea (SR18) is leaking at the RH CV boot. If I'm looking for the parts (partner says he can fix it), what should I be asking for! Good place to buy from! Would somewhere like Repco or Supercheap have them!
hijacka, Aug 5, 4:40pm
get a cv boot kit either will have it or order it in for you. $10-$20
cr4ftyg4l, Aug 5, 5:51pm
Thanks for that. I was of the impression I should replace the whole thing, because if it's leaking, there's probably dirt getting in. Does that sound right! Which case I think I'm up for a new outer joint!
intrade, Jul 27, 3:12am
never go to ripco they will charge minimum 2 times what the part is worth and what supersheep will sell it for. You go to auto- one supersheep partsmaster etc for pricesand if it is 70$ for the cv then that is the lowest possibile price you will ever find. a cv boot is 12 bux from supersheep.
