302w block Casting number.
jash3, Jan 26, 8:31am
Can someone tell me where to find it please.
evanscb, Jan 26, 10:52am
That number means nothing. The casting number is on the block , to the rear on the starter motor side. Check that out.
thunderbolt, Jan 26, 1:03pm
Once you find it, information here:
http://www.castingnumbers.info/site/browse/m/Ford/p/8 Where it is is here: http://www.mre-books.com/interchange/interchange2.html
The quickest path to block
identification is the casting
number and date code found
above the starter on the
right-hand side of the block
on 221/260/ 289/302, Boss
302 and 351W/351C engines.
jash3, Jan 26, 1:44pm
Right-hand side is that looking from the front! Looking from the front drivers side or the passanger side.
sifty, Jan 26, 1:48pm
Here's a hint - have a look on one side. If it's not there, it will probably be on the (big surprise) other one.
thunderbolt, Jan 26, 1:49pm
Same side as the starter!
Scroll down to the photo on the second link
jash3, Jan 26, 2:18pm
Thanks for that sherlock
NZTools, Jan 26, 4:50pm
Have a look at the machined surface the sump bolts to. ie flip your motor upside down on the engine stand. The stamped engine number will then be staring you in the face,
sifty, Jan 26, 6:05pm
well the motor is out, can't be too hard to find.
jash3, Jan 26, 8:47pm
You would think so but theres nothing there.
happylad3, Jan 26, 9:09pm
I'll have a look at my block tomorrow and see if I can find any more castings anywhere with the engine code id etc
jash3, Jan 26, 9:12pm
Cheers mate.
happylad3, Jan 27, 3:10pm
http://www.fordsmallblock.com/PDF/e-5.PDF
or in fact, even a 260. because the C4OE-6316A front pulley is only off the 1964 260 small block. easiest way to check would make sure the bore is 4" not 3.8" that a 260 has
happylad3, Jan 27, 3:17pm
has it got a 1 piece rear main seal! have a look at the rods for the casting on them
lookoutas, Jan 27, 3:20pm
It had 289 on the head.
And I see page 7 of the latest Petrolhead has 3 bolt front pulleys. (down the bottom) Assuming you were the punter looking for one.
jash3, Jan 27, 3:22pm
No its got ETTE on it
jash3, Jan 27, 3:23pm
Yes i was mate
lookoutas, Jan 27, 7:16pm
Sorry - someone else posted a head photo that had 289 on it.
jash3, Jan 27, 8:35pm
jash3, Jan 27, 8:37pm
jash3, Nov 7, 5:06pm
So it must be from the 80's!
