Castrol magnatec
jazzyjack1, Jan 27, 7:55pm
Does anyone know where you can buy this oil! (semi synthetic for a petrol engine) Supercheap or Repco dont stock these oils or Mobil 1
mugenb20b, Jan 27, 7:56pm
The Warehouse, Mitre 10.
ninja_man, Jan 27, 7:58pm
can you get a semi synthetic magnatec!
pup2, Jan 27, 8:03pm
trdbzr, Jan 27, 8:25pm
Magnatec is a mineral oil and is as common as milk in a dairy shop. Mobil 1 is fully synthetic and also as common as milk in a dairy shop. Me thinks you need to actually look inside repco and supercheap.
jazzyjack1, Jan 27, 9:20pm
sorry guys I meant to say 10w30 grade
trdbzr, Jan 27, 9:59pm
Magnatec never came in 10w30. 10w40 will not give any issues, its perfectly fine. What car is it for!
jazzyjack1, Jan 27, 10:28pm
2000 grand cherokee 4.7 V8 - continental cars sold me 5w20 when I wanted 10w30.that oil is too thin and is now leaking through the front main seal - dealers are such dumb arses. 10w40 will be ok with our climate and a push rod V8!
trdbzr, Jan 27, 10:35pm
For those engines I think it says to go for either 5w30 or 10w30, but im sure you can use a 10w40 without any issues. Alternatively Valvoline has 10w30 oil if you really want it.
mugenb20b, Jan 28, 5:36am
It's not the oil's fault. Replace the oil seal.
brokebloke1, Jan 28, 5:53am
+1 here
nulon 10w30 would be suitable and supercheap have it
jazzyjack1, Jan 28, 6:14am
its not the seal, its the oil - its too thin
pup2, Jan 28, 6:16am
yea, whatever. tui anyone. Replace the seal
mugenb20b, Jan 28, 6:20am
Don't be stupid! A lot of cars run 5w-20 and 5w-30 oils these days without a single oil leak. Falcons, Commodores, Mazdas, etc.
jazzyjack1, Jan 28, 8:13am
The rig had 10w30 in it before, no leaks out the front. as soon as I put the 5/20 in it leaked out when engine is hot. Maybe in Canada or Russia winter it wouldnt leak but here its too thin, speaking to Americans they agree also, dealers only advise 5/20 because its better on MPG. Im changing it over today and will advise if the leak has gone. Dealers dont know the difference between a catalytic converter and a resonator (Im talking your main line ones like CC, Precision etc. Local mechanics are good because they use their head and not a computer
tonyrockyhorror, Jan 28, 8:52am
Exactly.
tonyrockyhorror, Jan 28, 8:53am
Clearly jizzyjack1 isn't listening.
Good luck.
pup2, Jan 28, 9:18am
If it barks like a seal, moves like a seal and looks like a seal.ah nevermind. It's prob a duck
pfemstn, Jan 28, 9:24am
what a dickhead, of cause its the bloody seal. replace it
ema1, Jan 28, 9:48am
Sorry you are wrong there, I have bought it in 10w30 grade Castrol Magnatec recommended for my car( Toyota Avalon 1MZ-FE 3 litre V6).Only thing is you can't get it in 5 litre packs in NZ , it only comes in bulk 205litre drums so I've been told!
I get mine from my Toyota dealership.
Check here.Castrol Malaysia
www.castrol.com/castrol/sectiongenericarticle.do!categoryId.
ltz500, Jan 28, 10:06am
Sometimes the Mazda/ Ford dealers sell it here on TM its called Magnatec Professional. It comes in plain white stickered 4L bottles and is a little on the pricey side. Whats wrong with the standard 10W-40!, they had it for $25ish a bottle at SCA a while back.
ema1, Jan 28, 10:33am
jazzyjack1, Jan 28, 8:49pm
Rig had a oil change at 1.00pm this afternoon with 5w40. Have driven 200km and just returned home to reveal I dont have oil dripping down from the front main seal. Good thing I didnt rip the radiator out and belts just to change a seal, thicker oil solved the problem. when I changed to 5w20 not long ago it was 15km before it started leaking. Thanks all for your help.
bjdw, Nov 11, 1:55pm
Some oils that are developed for specific engines are only sold to the agents for that brand.
