VN UTILITY Diff - will a vp diff fit?
flemingo, Jun 29, 12:51pm
i am looking for a vn or vp diff if they fit for my vn utility. anyone know of any parts either. really just wanting to know if it will fit.
michelle322, Jun 29, 4:46pm
if ute has trailing arms and coil springs as in VN cars,yes vn/vp /vs sedan and s/w (non IRS )will fit.diff centers are interchangable but you will need to shim to suit.only difference is the shock mounts
joker9377, Jun 29, 5:59pm
Do the utes have different ratios on the VN/P compared with the sedan or wagons! Or is everything 3.08:1!
michelle322, Jun 29, 6:14pm
308 ratio for v6 and v8 .345 ratio option some where in the 2000 years
guider1, Aug 13, 2:18pm
3.08 in all utes, sedans, wagons unless later model (VT on) 6spd OR rare VP200 Clubsport which has 3.27 gears. VX 6spd is 3.46 as they have a slightly larger gearset. 3.45 ratio is from the VL.
A sedan diff will NOT fit a wagon or ute. the shock mounts are in a different place. Also VR/S is a tad wider.
You will need a VN/P wagon or ute diff to fit yours.
