thanks cjohnw. i will go onto that site and have a look.
cjohnw,
Jun 21, 8:29pm
No worries. if you decide to buy from them, apply for the discount card first.
Open to anyone, applies to everything instore, only takes a couple of days to get it by mail and will save you heaps.
I have saved hundreds over the years.
Regards.
bigracket,
Jun 21, 10:40pm
Disagree, go 2 pak, and never need to do it again.
maz61,
Jun 21, 10:41pm
yeah 2 pak is the way to go!
gmc350,
Jun 22, 5:05am
Unless its staying in the water,automotive 2k is all you need.Your car would spend more time wet.Keep it simple
diver211,
Jun 22, 7:55am
thank you all for all your imformation. will now go out and price all of these.
neville48,
Jun 22, 6:55pm
If you are going to use the marine gloss system make sure you are painting the same colour so when you scratch it ,it doesn't show like a glow, i would suggest this is std enamel with 93 plus or similar to harden it a wee bit. 2 pac would be better and harder for wear but reaction laquer undercoat and top coat would be the bee's knees, available from Nuplex, just a bit harder to use but a far superior product.
grangies,
Jun 22, 7:10pm
Are you planning on brushing/rolling it, or spray-painting it!
diver211,
Jun 22, 7:46pm
hope to sray-paint if i can.
elect70,
Jun 23, 10:31am
2pack reaction laquer is what I "ve always used on my boatshard as nailsesp good if you are launching on gravel beaches .
diver211,
Jun 25, 11:17am
thank everyone for there wonderful advice. will post a photo when i have finished painting it.
sr2,
Jun 25, 12:08pm
A bit off topic but I??
johnf_456,
Jun 25, 12:13pm
*polycraft
neville48,
Jun 28, 12:31pm
One wee bit of advice on the polyboat, keep it out of the sun as much as possible when yur storing it. New Zealands sun is hell on plastics especially plastics that are not UV stabilised, and there aren't too many of those around as time has proven, and one day it will split, probably around the topsides where it flexes and gets maximum sun.
sr2,
Aug 9, 3:53am
From what I've found out the modern generation of Polycraft are UV stabilised, hence the use of so many in the tropics. The main reason there are so few in NZ is that the importers also own a leading NZ manufactured brand and are (or were in the past) a little wary of going into competition with themselves.
