holding the deck on to my ute.Any way I'm gonna get'em off without gas or cutting anything!
pollymay,
Jun 23, 8:43pm
lots of penetrating oil like PB blaster overnight soaking, give it a go. Then try some heat and if still a no go keep the heat on till it moves and it'll either go free or pick up the thread but if it's that tight it's that tight.
Assumes you aren't gunna set nearby things on fire.
jmma,
Jun 23, 8:44pm
Angle grinder
snoopy221,
Jun 23, 8:45pm
NOPE
mopar63,
Jun 23, 8:46pm
just use a big power bar and hope they break, easy
bjdw,
Jun 23, 8:59pm
's what I was thinking.The scrappers 30km up the road got a good cheap replacement deck for me and I was wanting to get it loosed up and easy to get off before I took it up there so they don't gotta f*ck around too much and therefore charge me more.So I guess if I canbreak the bolts and hammer'em out and put good ones in, all good.But if I gotta cut the deck off, no way I can drive it 30km safely. (He want the old deck to get the good one cheap)
bjdw,
Jun 23, 9:06pm
Sorry if I'm not making sense, too many beers.
mopar63,
Jun 24, 4:53am
well then you could just cut them off then used tied downsto hold ya deck on for a short trip
desmodave,
Jun 24, 6:58am
Time is $$$$$ cut the bastards off.
johnf_456,
Jun 24, 7:44am
Hammer and if that fails get a bigger hammer
crzyhrse,
Jun 24, 9:08am
You'll need heat. No two ways about it.
thejazzpianoma,
Jun 24, 11:21am
This would be a great test for some of that "nutcracker" stuff from powerup. I would be keen to hear if it worked in this "extreme test", have been thinking of getting some myself!
bjdw,
Jul 20, 1:14am
I wonder if it is the same as Loctite Freeze and Release which you spray on and it makes the nut and bolt really cold so they shrink away from each other and the lubricant can get in.Its about $25 a can so I don't want to try it unless I know it will work.
