SLR TORANA. What is the stud pattern on my lh amp is there any vehicles withthe same pattern i would like to from a 13 inch to m
lumpster, Jun 21, 7:05pm
What is the stud pattern on my lh & is there any vehicles withthe same pattern i would like to from a 13 inch to may be a 14 - 16 inch
lordv81, Jun 21, 7:30pm
Your stud pattern is 5x108 same as 4cyl commodore and HT.HG.HK holdens.Some newer european fords have the same pattern but wrong off sets.There are brand new mags listed on TM to fit for as little as $600.I have some 14s on my sunbird Ill be selling if you are interested!
hatchback, Jun 21, 7:33pm
If its the small pattern ie 5 x 108 then pretty much nothing standard fits except 14" ht holden. Might be hard to find an aftermarket wheel too.
lumpster, Jun 21, 7:38pm
What do the mags look like lordv81 i might be interested
whynot7, Jun 21, 7:55pm
be very carefull with the offset . the wrong ones will rub on the rear shocks .or the gaurds, not much of a choice in magwheel options unless you spend big money
guider1, Jun 21, 10:18pm
Best thing to do is get your axles re-drilled to HQ pattern & fit HQ front brakes. much wider range of rims available then.
That's what I did to both my LH & LX Toranas, except I fitted a 9" to them both as well & had the axles re-drilled.
lordv81, Jun 22, 9:06am
Hi,they are cheviot Quatros.They are like a mesh style centre and are 14x7,they fit well with no rubbing.I have them on a sunbird at the moment but am putting on a set of hotwires.
bopbargains, Jun 22, 5:01pm
Volvo use the same stud pattern.
jezz43, Jun 22, 6:08pm
i got some cheviot turbos, 14x8 with 236/60 R14 BFGs on them. all holden fitment
whynot7, Jun 22, 6:11pm
yes, so do new model jags and ford taurus and they rub big time on the rear an have no lock on the front
xacoon, Jun 22, 6:16pm
what are the tyres like jezz!
jezz43, Jun 22, 6:18pm
around 5mm+ each tyre. they are in pretty decent knick, just need to be cleaned as they have been sitting a while. im after modgies so these will have to go
xacoon, Jun 22, 6:27pm
so you want rims and tyres gone then! I have rims for africa, just tyres I might be interested in.
jezz43, Jun 22, 6:29pm
im happy to sell tyres alone, i was planning on using cooper cobras anyways. i like the BFGs, but god they are hard to get nowadays
klrider, Jul 15, 3:59am
I dont care, Im just jealous and wish I had one.
