Rev gage on s14 silvia
narnies, Jun 22, 7:45am
Has all of a sudden gone nuts, it has a spastic and then it just wont work. cant figure out why! anyone else had this happen!
morrisman1, Jun 22, 8:43am
Its a nissan thing
moosie_21, Jun 22, 12:54pm
relay may be frayed/snapped, check that
escort72, Jun 22, 1:17pm
Its generally a fault with Nissans, absolute pain in the ass.
morrisman1, Jun 22, 2:37pm
morrisman1, Jun 22, 3:14pm
thats your partner's job
narnies, Jun 22, 4:24pm
how do i check the relay!
bae13, Jun 22, 6:06pm
what relay do you want to check, the tacho doesnt have a relay. the only relay would be the ignition relay, but the car would be cutting out at the same time, your issue is with the dash, i would be 99% sure of it, nissans are very common for this,you could send to me for repair if you like, see myprofile for details
narnies, Jun 22, 6:42pm
What you mean with the dash as in a loose connection! its not affecting the car at all just the rev reading on the dash.
bae13, Jun 22, 7:13pm
the dash as in the gauge cluster assembly with the temp, fuel, speedo, tacho in it,
i said if it has a relay fault, the only one that would affect tacho will be the one that does the ignition system, if that was the case the car would cut in and out, it doesnt. so your fault i suspect is in the dash cluster/gauge assembly
narnies, Jun 22, 7:14pm
Its only started doing it since its had a new head unit put in.
narnies, Jun 22, 7:27pm
googled it and someone had a similar problem and it was the diode!
fordkiwi27, Jun 22, 7:30pm
heesssss baccckkkk
andrea_w, Jul 14, 12:14am
OP : It has zero to do with a head unit, period.
bae13 will be correct. the fault will be in the instrument cluster somewhere (well as said. a 99% chance)
