Does anyone know if a 2 litre pinto engine will just bolt in to a Mk3 Cortina that has a 1600 in it! Wanting to put a 2 litre in to it have been told that it will just bolt in but not to sure, also will a sierra 5 speed bolt in to it too!
bubbles52,
Jun 14, 7:11pm
no it wont, youll need the 2.0 engine mounts, the sierra box will bolt to the engine, but you will need to have your driveshaft shortened
quickstitch,
Jun 14, 7:21pm
and make a gearbox mount. (and sort out the speedo drive) and while you are under the car fit a driveshaft safety hoop, you will need one for cert as it is a repowered car.
unclejake,
Jun 14, 7:21pm
Is it a 1600 crossflow or OHC you have in there now!
kraines1,
Jun 14, 7:22pm
buy a 2L mk4/mk5 cortina that is suitable for parts and swap the whole front end over, they bolt in. and the mk5s have larger swaybars so a slight improvement on the handling. a 2L cortina driveshaft is suitable for a 4 or 5 speed gearbox. and to mount the 5 speed sierra gearbox you will need the gearbox crossmember off an automatic 2L mk3, 4 or 5 and the sierra speedo cable (longer than a cortina one). all is a bolt in and requires no modification to the cars body or driveshafts etc
boom123,
Jun 14, 7:25pm
Its just 1600 OHC with 4 speed and want to go to 2 litre OHC
kraines1,
Jun 14, 7:27pm
engine mounts should be the same then
cuda.340,
Jun 15, 4:56am
straight swap as noted, did this myself in the 80's
big.b-lil.c,
Jun 15, 5:10am
i have used the original sierra cross member with a short length of (around) 1 inch square box section welded to it and two holes drilled thru it to bolt into the original holes on the vehicle. if you want a real good 2.0ltr and 5spd watch my auctions next week.
brokebloke1,
Jun 14, 4:59am
why piss around with old technioly put a zetec motor into it much better car then, im in the throws of putting a zetec in to a mk2 escort with the 5 speed from a sierra sw, going from 1300 to 2000cc
