for a full service on a 1997 subaru gtb legacy. Cheers.
wellabolla,
Jun 5, 7:44pm
if cambelt and tensioners are done.plugs,oil and filter etc etc.you can expect to be as high as $1000,and thats speaking from experience
sd8888,
Jun 5, 7:46pm
cambelts been done im just thinking all the oils be changed and filter
johnf_456,
Jun 5, 7:49pm
Hard to say depends if anything needs doing.
sd8888,
Jun 5, 7:55pm
sweet thanks guys
hijacka,
May 11, 7:04pm
The 97 gtb ej20 engine has shim over bucket heads so oil would be a 10-40w or 10-30w fully synthetic, becareful you don't choose the 'Cheaper options' you will end up running bearings! Oil will cost around $60 then ryco filter $14
