Glass from instrument cluster, 94 surf
davetikey1, Jun 5, 3:59pm
can you buy the glass from the instrument cluster on a 94 surf newor would a wrecker be the place to go, how much do you think they should be worth
franc123, May 10, 7:10pm
A wrecker is probably going to want to sell you a whole cluster, you might get a good one for $100-120 if you are lucky.Toyota may be able to supply a new one if the lense on its own is a fast moving part, if its not and has to be ex Japan it may be a lot more expensive, I'd still give them a ring anyway with your model and frame numbers, or even just the rego number and enquire.
