Headunit installing help needed
deanfreeman, May 31, 4:02pm
trying to put a near new head unit in a toyota spacio and the cables in the car ar diffrent colourd to the cables on the unit apart from some i had it working but the screen was flickering but now it doesnt want to go at all
johnf_456, May 31, 4:06pm
Sounds like you have blown a fuse because you don't know what you are doing, you should never install head decks going by colour choice. The best tools for the job is a test light or multimeter and a 9v battery for finding what speakers are what. If you were unsure you should have taken it to a sparky.
jasongroves, May 31, 4:09pm
You need a multi meter or a test light.and probably someone who knows what they are doing;) Lol.
What is the head unit!
What year spacio!
mugenb20b, May 31, 4:11pm
Did you buy "Toyota to head unit" plug adaptors. If you go to Repco and you buy a Sony head unit for example, you can get Toyota to Sony adaptors.
johnf_456, May 31, 4:11pm
Test light for finding constant 12v and acc 12v or a multimeter which will tell you which wire is live etc by giving a voltage reading. Pretty simple, basic basic electrical knowledge.
jasongroves, May 31, 4:12pm
jasongroves, May 31, 4:14pm
Probably easiest option.unless something has already been shorted out:(
bluecambridge, May 31, 4:14pm
you need a couple of adapter harnesses from supacheap, the first is "toyota to generic" the second is "generic to your brand of head unit". No mucking around just plug the first adapter straight into existing toyota loom, then plug the second into that, which in turn plugs into your head unit.
Yep, just make sure you don't wire the 12v acc to an illumination wire by mistake;)
johnf_456, May 31, 4:16pm
Yeah being there done that, negative when ignition off and live went ignition on then bye bye fuse and tail lights. Old memorys from the first time I did them haha.
deanfreeman, May 31, 4:29pm
fuse on the stereo is still good i checked that i think ill get a auto elec to do it ive cut and stripped all the wires last time i got one to do it it took him 10 mins to soilder it all up and get it working its a panasonic headunit and a 98 spacio used to have a tape player factory standard
jasongroves, May 31, 4:32pm
Wont be too hard to sort out.
Have you checked interior and under bonnet fuses!
Once you know which wires are which, disconnect the earth lead from the battery before wiring everything up.
jasongroves, May 31, 4:34pm
deanfreeman, May 31, 4:36pm
nope but shud be algood every thing still works
jasongroves, May 31, 4:38pm
jasongroves, May 31, 4:41pm
To test the head unit, twist the yellow and red wires together. Briefly touch these to the + terminal on the battery while holding the black wire to the - terminal.
If there's no power to the head unit, then you have blown something inside the unit.
johnf_456, May 31, 4:43pm
Also some headdeck need the power button pressed down for a few seconds to make them turn on for the first time.
deanfreeman, Jun 1, 1:17pm
ok so i tested the head uniot it stil works but im just trying to get it to work in the car ive got yellow yellow and blue yeloow striped black on brown green black strimpe dark. on darck green silver dots stil wont fire up trying to use these for help but stil not working does everything have have to be hooked up in oreder for it to work or just earth power ! using this http://www.the12volt.com/installbay/stereodetail/2065.html
jasongroves, Jun 1, 1:43pm
Could you be a little clearer on the wire colouring please!
Something like:
Yellow.
Yellow and blue.
Black.
Etc etc.
jasongroves, Jun 1, 1:48pm
You might find this one easier, its the 2nd one:
http://www.installdr.com/Harnesses/Toyota-Wiring.asp
For a start, blue with yellow stripe is the constant 12v, so goes to the yellow wire off your head unit.
The grey wire in the car goes to the red wire off the stereo.
Etc etc.
Do you have a test light! As there are 2 black wires coming from the factory car loom, 1 is ground, other is a speaker +.
Should be pretty easy to tell which is which as the ground wire will be grouped with the other power wires.
If you are not sure, run your own.
deanfreeman, Jun 1, 2:05pm
wel in the loom with the speaker thing there is a brown cable and cant find anything on a brown coloured cable dont have any tester things have done a few cars before but this is the first time ive had trouble with getting it going probly because its never had an aftermarket one in and my previous cars had
jasongroves, Jun 1, 2:14pm
Well, do you have the yellow with blue striped wire, grey wire and black wire!
Otherwise, pop into Jaycar or Supercheap and grab a cheap meter or test light.
deanfreeman, Jun 1, 2:33pm
on the whole lot or just the car wire not the headunit wire
deanfreeman, Jun 1, 2:40pm
ok there are 2 seperate looms on has a red black white yellow on the other is a light green blue blue/w yellow stripe dark green browny colour purple pink and a light grey
