Whats that stainless steel plating called?
samage, May 29, 10:44am
you see it in cars and boats etc. has like a grib mould on it aswell! any1 know! cheer
extrayda, May 29, 10:46am
checker plate!
samage, May 29, 10:47am
yeah thats the 1 cheers
biddy6, May 29, 12:07pm
Steel and tube , Vulcan steel, Fletcher steel, Mico metals.
Try these places, they will know were to get it. Are you sure you want S/S, mostly Aluminium or steel checker plate is the commonest used. If you just want a small piece, ie; not a full sheet, try various engineers shops or Sheetmetal shops.
samage, May 29, 12:29pm
yeah i would be after a full sheet of it as im gona use it for a floor in my boat to replace the old ply 1, will try these places cheers
m16d, May 29, 12:31pm
Crikey the stainless floor will be worth more than the boat.
im_andrew, May 29, 12:35pm
Pretty sure it normally comes in alloy or steel, never actually seen it in stainless
vag.central, May 29, 12:36pm
Use alloy, stainless is heavy, go to a profile cutting shop and get it cut out to suite the boat
toppo1, May 29, 1:00pm
Use alloy for sure, lay old ply sheets over top to trace around. Use a jig saw with CRC to lubricate the blade to cut it.
unclejake, May 29, 1:25pm
Alloy is the best thing to use. It is often called grip tread plate
h.e, May 29, 1:33pm
ullrich aluminium,kaikora valley rd dunedin
