What do I call the key thing that
kmw01, May 24, 2:45pm
I turn in the control box to activate the hydraulic ram on our truck! And where can I buy one from - or am I looking at having one fabricated!
poppajn, May 24, 4:04pm
The key thing!Is that John!
h.e, May 24, 4:33pm
pto switch!never seen a key type switch
bigfatmat1, May 24, 4:35pm
maybe a battery isolator key. take a photo and show us what you mean
kmw01, May 24, 4:48pm
umm how to explain. it's a stainless bolt type object that you insert and turn in the control box under the truck. about 10mm diameter, has 2 "pins" at the end which activates the box, enabling you to use the buttons for the ram.
Clear as mud!
gilco2, May 24, 4:57pm
yeah, it is a start key you should be able to get one from TWL or most auto electricians should be able to get them. I used to have a couple spare onesbut not sure if I still have them. Very common on heavy machines. battery isolator switches and master switch. Just ask for master switch key. I have only come upon 2 sizes in my time
Just looked Hella book part number should be 4654 Hella number. May have changed as my book is 2 years old now
kmw01, Mar 28, 7:56pm
brilliant! Thanks so much
