U13 Bluebird Questions? please
dasfi, May 21, 6:18pm
Speedo always satys at 60kmh, Guessing its the cluster and i need a new one! also sometimes the starter motor will half turnover then stop and sometimes do nothing! Guess it would be the starter motor! Thanks
jasongroves, May 21, 6:29pm
Is it only the speedo!
Or is the odometer not working either!
Get you battery checked first.including connections/terminals.
Starter motor failure is pretty common on SR powered vehicles but always start with the basics first.
Could be starter motor pinion or ring gear.but check the above first.
dasfi, May 21, 6:31pm
odometer works and clocks up ks but just the speedo dosnt
xs1100, May 21, 7:01pm
was having a similar problem with a pathfinder wereby the needle wouldnt go over 80ks and the rev counter over 3k.took it for a GOOD long trip the other week from pukekohe right out onehunga and back and now is fine again think it might just be getting old and tired.take it for a good run sounds like battery needs a gd run also
jmma, May 21, 7:08pm
Maybe gearbox oil coming up the speedo cable
dasfi, May 21, 7:32pm
nothing to do with battery, i have had an amp load test thing done on it, i know nissans arnt the best for starter motors, had a quick look for it but cudnt see it, looks like may have to get to it from underneath
jasongroves, May 21, 7:43pm
Yep, at the back under manifold
phillip.weston, May 21, 7:45pm
What speedo cable! :P
dasfi, May 21, 7:45pm
sweet as pretty sure its the starter motor, and ill try replacing the cluster, everything else works on it just not speedo
dasfi, May 21, 7:50pm
what else may cause it to not go above 60!
jmma, May 21, 7:51pm
Sorry, showing my age and ignorance (o:
http://www.heartofpelorus.com/Nissan_U13_speedo_repair.html
This might help then
dasfi, May 21, 8:01pm
Well i could try heating and freezing it a few times, have nothing toloose as it dosnt work anyway
candy1213, May 21, 9:48pm
speed sensor ,get another one and try that
nissan startermotors, eat brushes,,or clog up with the old brush dust, get a second hand one /rebuild your old one/ brand new one too, very cheap up north google for nissan bluebird parts,nz
dasfi, Mar 19, 9:52pm
Also forgot to mention, if i rock it in park a it can get it to start,
