My current Beamer (M330) has a battery issue.Even with a new battery, t does flat if not driven for three weeks.It has a newish (calcium) battery - one year old andis OK.Team McMillan has run its diagnostics over it and decided to change the cellphone hands -free toonlyactive in drive.Alarm system has been checked too - including by Mongoose. All previous Beamers did not have this problem. Anyone else have a similar problem!And, if so, what was the solution! As a frequent traveller, I want to be solve this without doing anything cumbersome, such as removing the battery before each trip.
berg,
May 20, 8:01am
Check the boot light is going out. It may take somebody laying in the boot when you shut it but that can often be a problem.
footplate1,
May 20, 10:53am
Well, I don't think you will be helping TM!I have found nearby (GI) place that services Beamers.And my wife's Swift.But, in case they are as lost as I am, I thought I would seek informal advive too.Yes, the blower fan does continue for a while, but not that long.Interesting point about the boot light.I bet TM hasn't thought of that!
Thanks, all.
321mat,
May 20, 10:55am
The Chinese mafia in Auckland often have that problem.
I wonder if they've had any warranty claims after any failed kidnapping attempts!
321mat,
May 20, 10:57am
Oh, and Team MacMillan don't seem to have the good servicing reputation that they'd like you to think they have, do they!
pandai,
May 20, 10:57am
Is the car in the garage at home!I dare say, the simplest solution might be to put a small ctek maintenance charger on it while you're not using it.
ginga4lyfe,
May 20, 11:02am
Footplate, Take it to north shore , to Burgers Motor works, he is a top bloke he should be able to find the problem! From memory its 95C Wairau Rd Glenfield
footplate1,
May 20, 3:10pm
No, sadly.I can't get the damned thing over the concrete lip to a steep grade into garage.The car is too low-slung.
footplate1,
May 20, 3:11pm
Thanks.Know the area roughly as one of the things I did was have the alarm tested by Mongoose.
saxman99,
May 20, 3:47pm
Surely you mean "2nd best.!'
budgel,
Mar 16, 4:17am
I agree with Bob1120, he recommended them to me for a pre purchase inspection.Mind blowinglythorough, and professional to deal with.
Thanks Steve.
