vehicle towed to my shop 5pm after not going for 3months and been to 5 or so workshops.
quick glance over
No fault codes upon scan
sparkplugs fine ht leads fine coil fine igniter fine airflow metre fine fuel pump fine
has spark,has fuel.(pressure)
so any chev experts out there ,to save me time in morning : )
have a vehicle identical i can borrow tomorrow.
ct9a,
May 17, 4:20pm
i added 2lires oil,drained and refilled petrol. also
the vehicle was driving along flat open road and just died it winds over ,smells rich as hell
unclejake,
May 17, 4:28pm
I wonder if the valves are opening and closing!
petermcg,
May 17, 5:12pm
common problem for these blazers are the fuel pumps,,,,cap and rotor,,,,,ign switch
ginga4lyfe,
May 17, 5:14pm
Tested Cam timing and ign timing! tested to see if the Cam angle sensor is working ( if it has one ), I know some electric ign vehicles have a pickup on the main pully of the crank and if the key has broken and the pully shifted the timing would be all over the place, Just a few other cents I can put in
unclejake,
May 17, 5:20pm
I don't know these particular motors, but a crank angle sensor will trigger the spark with a broken cam drive.
There is no mention of compression in the original post - hence my thoughts wrt valves opening and closing
smilie13,
May 17, 6:23pm
check at night because they are known for the high tension leads shorting out on a rubber hose. sounds funny but true.
ct9a,
May 17, 8:04pm
has compression yes valves are opening and closing no crank sensor on this model
thanks petermcg for heads up will check in morning.
petermcg,
May 18, 4:24pm
these trucks wont start if the fuel pressure is to low.
ct9a,
May 18, 4:32pm
how funny that there are 3 in my area in workshops that wont go
have found so much info via american sites regarding these have done many test,suddenly now the fuel [pump is working,also had no fuel,now removing cap/rotor which are stuffed,tip of rotor has gone : )
must say in all my years by far the worst vehicle to work on ever
thejazzpianoma,
May 18, 6:22pm
Just a thought, if you are having random fuel pump/fuel issues and it smells rich don't forget to check the fuel regulator and fuel solenoid as well. Smelling rich can of course be the fuel pressure regulator not doing its thing, of course a fuel pressure test will sort that.
Have fun!
treachug,
May 18, 7:44pm
Or the coolant temp sensor (if it has one, lol) has failed telling the ECU the engine is cold all the time so richen up until warmer. Yep, one of the biggest POS ever imported in NZ via Japan.genuine oddball model!
ct9a,
May 19, 6:45am
sparkplug gap average 3.2mm ! #1,2,5 HT lead poked Tip of rotor missing Cap has arcing galore
think i am on to something : )
gilco2,
May 20, 7:29am
Hey, I am curious, did you have any success with this where others had failed
ct9a,
Mar 12, 4:19am
yeah i sure did! and how awesome was it that the only stockist of parts was in my home town!
hard case one at mates shop ,similiar issue,after 2k at other shops he fixed in 2hours.after 2months in shops.
