hello all, i come with 2 questions, first; my ga14 nissan pulsar n14 has a crack in the exhaust manifold as shown in the picture (they arent green and red, i coloured to make it easier to see) http://img853.imageshack.us/i/pulsarmanifoldcrack.jpg/ does anyone know how i can fix it. i'd like to attempt to fix it because i'm a new zealander, and because i'd enjoy the learning. If this isnt viable for me to do then i'd be more then happy to buy a replacement the tools i have avaliable is a high quality mig welder with argosheild and an acetylene plant, would i be okay to "v" allong the cracks then lay some thick, deep welds or would they crack! or perhaps braze it! (as before, i don't mind if i mess it up, i'll be richer for the experience and can buy another.)
remove radiator,use a flap disc on grinder clean up area and go nuts with what ever welder you like
marmatt,
May 15, 10:21am
i would put some heat into it before you weld itas its carstmig should do a farily good job
eronacax,
May 15, 10:38am
it's easy enough to pull the manifold off and do a nice job of it, so i could pull it off, clean up around the cracks, crank the power up on my mig, heat the whole thing with oxy/acetylene torch then give it a zap! let it cool and see how she stands up!
h.e,
May 15, 11:17am
your manifold is cast iron mig is steel,these expand and contract at different rates it will more than likely crack again and make a proper repair harder.prep it as in v the crack heat it up arc weld it with cast rods,heat it again when finished and cool slowly in sand or a hot oven.you can get rolls of cast for the mig but its very expensive.the most successful way i have come across is to gas weld it with cast filler rods pre heat post heat cool slow good luck
rob_man,
May 15, 12:26pm
Ooooeeerr. "Refitment" now is it!. Come in here with your big words. Bloody show off.
johnf_456,
Feb 20, 2:17pm
Yup, give it a shot, worse comes to worse just get another one
