Milage 295360 is this high?
tajarn, May 12, 12:45am
on a holden commodore berlina 1994 how many more could it do!
pollymay, May 12, 1:03am
between 0 and another 800,000
scoobeey, May 12, 3:55am
345678km thats it:)
321mat, May 12, 9:37am
They can (and will) go forever - IF cared for.
The motor is relatively low stressed, and since it has a (relatively) long piston stroke, there is little thrust pressure on the rings, and even less on the main bearings, etc.
With a good oil, such as Castrol Edge 0w-40, or Mobil ONE 0w-40, I see no reason why this motor won't rock on for another 500,000 kilometres.
BUT REMEMBER:You need to look after it - and by that I mean regular oil and filter changes.And don't forget the air cleaner.
johnf_456, May 12, 11:10am
Not for the engine but give the body a good going over.
40wav, May 12, 11:12am
Thats just run in.
rovercitroen, May 12, 11:25am
And don't neglect the coolant. These engines need good coolant of the correct strength.
rob_man, May 12, 3:10pm
That's low ks for a space shuttle.
chris241, May 12, 3:28pm
I Have a 1994 ss commodore thats done 325,000Ks still runs mint and goes well
attitudedesignz, May 12, 3:40pm
My VR ute's done 310,xxx and no sign of giving up anytime soon.
tajarn, May 12, 6:26pm
awesome yes i will take the advice of all the above givn thanks eps im feeling better about the sale already im pickin it up tommorrow woohoo!
grangies, May 12, 7:00pm
The body and running gear, will most probably die before the engine.
johnf_456, Feb 10, 1:16am
Yup depending how its treated, its the body that gets costly, mounts, bushes, suspension parts, possibly even rust. But as long as you do your homework it should be fine.
