recently taken out my ecu from my 96spec type-r , i was wiring a vtec light to a blue wire (vtec wire) realized i got the wrong wire ,electrical taped it back up and spliced another. not long after then i drop my ECU not a massive fall, maybe 30cm drop (onto carpet),it was starting when the ECU was out but once i put it back together my car didnt start =/ . clueless here,any help!
bash,
May 11, 4:53pm
get a car without one then there is no problems
lazz323,
May 11, 4:54pm
and what car dosen't have a ECU!
lazz323,
May 11, 8:04pm
totally got storey wrong, i didnt mean vtec light , i ment RPM wire., doubt it can do damage as the wire i tried to connect was not live. just a wire trying to get a signal. can anyone help look for a decent p73 (p73=type-r ecu code) or type r ecu pinout!
sr2,
May 11, 8:22pm
Maybe ease up a bit!It??
a18a,
May 11, 10:37pm
ecu wouldn't be damaged from the drop. i have a few that have been thrown around, soaked in water and not really looked after which still work perfectly fine. does the main relay still click and pump fuel when you first turn the key on!
alltorque350,
Feb 8, 5:09pm
checked the fuses!
