I always found masking tape worked quite well with cuts and things.
xacoon,
May 6, 6:56pm
duct tape is no good, blood makes it slide right off. making tape with a bit of insulation tape over top is the go
hijacka,
May 6, 7:11pm
Looking before grabbing is better;)
sigvat1,
May 6, 7:19pm
didnt no you had your own teeth rob i thought you used steredent
ginga4lyfe,
May 6, 8:02pm
you should have got it all washed out then put a verrrry small blob of superglue on it to close it up, I found that it always worked well, and im still only slowly dieing
sr2,
May 6, 8:15pm
LOL; I??
pollymay,
May 6, 8:35pm
Superglue rocks, works on fingernails to
jono2912,
May 6, 8:54pm
mellisa2000 wrote: Superglue. :) Sh1t mate, you better hope its not the pick fingers. No Stat for you. :-([/quote
Yeah, superglue.
To stop it bleeding (if you have the time) pressure and height is the trick.
unclejake,
May 6, 9:44pm
Before you put the masking tape on you should always spray the cut with brakeclean.
That way we know that the wound is clean and if you are a man
jono2912,
May 6, 10:37pm
That hurt thinking about it.
snoopy221,
May 6, 11:53pm
Gawd and ta tink there were tampax's without a job cause of slack.c****.s.LOL
johnf_456,
May 7, 7:02am
Reckon
xacoon,
May 7, 3:26pm
all my years of playing, and it was never the fingers that ended up bleeding.
amber.gumdrop,
May 7, 5:23pm
Superglue works like stitches, make sure its clean, apply pressure for a bit and then pop a really small drop in and close up the wound flaps.
johnf_456,
May 7, 6:59pm
Have a beer rob!
hijacka,
May 7, 7:13pm
Thankgod for that, i was going to tell you to change your user name to rob_girl, The bleeding crouch would have been better!
lookoutas,
May 8, 7:39am
Going by the heading - I was gunna suggest to get someone you trust to pump the peddle!
roys351,
Jan 27, 8:50am
haha i dip it in meths works a treat for zits too
