The Air Con in my Honda Accord has become very temperamental recently.It wasnt working when car first started, then coming on after the car had run for a while.We put new battery in at the weekend, but still having the same problem.In fact, it wouldnt go at all this evening when I was trying to demist windows. Can anyone give me some ideas that we can look into please!
May 3, 6:16pm
You most likely have a small gas leak. Usually the system can be recharged (topped up). Best to see someone who does auto A/C, they'll be able to diagnose the fault.
jasongroves,
May 3, 6:16pm
Start with the basics and check the auxiliary belt that runs the A/C compressor. Could be an electrical problem or may even need to be re-gassed. Worth checking for leaks too. What year Accord!
shane.64,
May 3, 6:23pm
Maybe check the fuse if the fan is not running .You don't need A/C for heat to demist the windows but the car engine needs to be worm
charlieb2,
May 3, 6:24pm
Thanks for the ideas.
She's a 1994 US wagon, been a great car, cost us nothing since the day we got it basically. (except the new battery at the weekend! lol)Still relatively low km's (130)
jasongroves,
May 3, 6:24pm
A/C is the best way to demist windows;) Worm! Lol.
charlieb2,
May 3, 6:26pm
yeah, when I said 'air cond' I mean that whole panel is not working immediately. I dont really use the 'air con' except in the winter for heating sometimes. the button to 'demist' is in the panel and I just hit that normally
May 3, 6:29pm
And there's your problem. You need to use it at least once a week. I never turn my one off.
bigfatmat1,
May 3, 6:33pm
They are a common failure the control panel power supplies stuff out. They can be fixed as they are like hens teeth to buy. But thats only a stab in the dark
charlieb2,
May 3, 6:43pm
Yes, Mr keeps telling me that. but I dont think about it, lol.
Thanks everyone for the suggestions.
tmenz,
May 3, 8:49pm
If the gas pressure is low, the low pressure switch fitted to the system will not allow the compressor clutch to engage - therefore no cooling. Sounds like the pressure in yours is right on the limit for the switch so sometimes it allows it to work - sometimes it doesn't!
camerong1,
Jan 10, 12:09am
I use to have one of these cars and had to replace then control panel and that solved all the problems. This was a common problemwith these cars. I brought a new panel off a guy on here who fixes them and he can also fit them took about 1/2 an hour to fix.check out this listing 372777657 this was what I brought
