LD28 Sump pan
jjc09, Apr 23, 2:16pm
Does anyone where i can get one of these cutom made to fit into i nissan c33 i have one here but the oil pick up is mid way mounted so it wont clear mi cross member
jsbike, Apr 24, 10:45am
does an RB sump fit!
jjc09, Apr 24, 7:05pm
unsure at this stage will be trying that tonight
jjc09, Apr 24, 7:07pm
if that doesnt work are sumps hard to weld
jjc09, Apr 25, 1:32pm
Well that was an epic fail tryed it and rb sumps are longer "bugger" any other ideas!
jsbike, Apr 25, 4:51pm
didnt c33's come out in diesel! use one from a factory diesel! same goes with the alternator
jjc09, Apr 25, 9:26pm
yea they did come out factory with a RD28 diesel in them but i changing mine to LD28 because they are a stronger motor as i have gone though 3 RD28's in less than 3 months.
The LD28's came out in the model before C33 they were in the C32's which from what i know run a different sump to the C33 as for the alternator the max that i know of from the LD28 was a 50 amp because these are from older vehciles which didnt need as much amps to power it
bert37, Apr 26, 7:26pm
pretty sure the ld28 came with either front middle or rear oil pickups and front or rear sumps, rd28s were crap would be a great car with a turbo ld28, try and get a c32 radiator as well they do fit in and cure all c33 heating problems
1ollie, Apr 26, 7:30pm
Get a L20E/ET, L24, L26 or L28 one as im sure they are the same
jjc09, Apr 28, 10:24pm
Is this radiator you speck of for a RD28 or LD28
jsbike, Apr 29, 9:22am
one of the best places to get diesel parts for the laurels is on the d1nz forum. usually quite a few parts seeing they tend to convert diesel to Rb turbo. Sighn up and place a wanted advert http://forums.d1nz.com/
les37, Dec 23, 9:10pm
i think from memory a l20 skyline turbo sump fits, and the l20 turbo intake and exhaust manifolds bolt straight on, use a ld20t,, 4 cyl compensator valve,(top off injector pump)
