How do i strip
loudnproud, Apr 25, 1:55pm
the inner sound deadner/black rubbery stuff from the inside of my ute! its all over the floor and walls. any help appreciated
johnf_456, Apr 25, 1:57pm
Get some c4
v8_mopar, Apr 25, 2:24pm
Petrol will sofen it as it soaks in but its a sticky mess to remove and takes time
afer_daily, Apr 25, 2:38pm
go down K rd some of the girls [ and boys ]will give you lessons .
ginga4lyfe, Apr 25, 2:39pm
Paint stripper! Though you would have to repaint the floor
quickstitch, Apr 25, 2:42pm
scrap the bulk of it off with a scrapper or chisel, and then get the residue off with petrol. have fun.
loudnproud, Apr 25, 2:43pm
sweet thanks for the advise, i might get some C4, put the ladyboys in from K rd, fill interior with petrol and paint stripper and throw a match.that should do the trick
unclejake, Apr 25, 2:51pm
Getting the sound proofing as could as possible helps. Dry ice and a chisel will get it off. Some of the early mats came off with a bit of heat (to soften the adhesive) but the more modern mats seem to get harder to remove with heat
I have had good luck with an air chisel on soundproofing, but you do risk some damage to the parent metal.
If your ute has a spray on product then the above will not work
shuddupowh, Apr 25, 5:43pm
I read in a car mag that dry ice is the easiest. Make sure you wear gloves and put it all over then once its very hard just chisel it out - expect a weekend to do it. Search Google, bound to be a step-by-step guide. And if stripping the spray on crap on wellsides (spray on tufdeks), petrol is best cos its not resistant to petrol.
ola_bitchola1, Apr 25, 5:45pm
in my car i just used a hammer that seemed to loosen it up then managed to pry most of it up with a screwdriver
rscozzie, Apr 25, 7:20pm
hot air gun and scraper gets it off easily
ola_bitchola1, Apr 25, 7:46pm
its gets pretty messy like that however compared with dry ice or chipping it off
thejazzpianoma, Apr 25, 9:55pm
Being in a main centre it may be worth a call to a dry ice blaster to get a price. Dry ice blastingis by far the quickest and easiest way to get under-seal type stuff off.
ofive, Apr 26, 6:29am
Dry ice noobs.
thejazzpianoma, Apr 26, 8:33am
Not really. I have a cold - jet ice blaster sitting in my garage!
joanie32, Apr 26, 8:42am
Thats whatIuse. its not that hard ormessy to do.
toycon, Dec 11, 10:05pm
Why wud you want to take it off.
