Hi all wanting to clean up the sheet aluminium in my saloon. It is oxidized and stained with clay etc, is there anything that I can use to get it back to looking shiny and newish!
smiller18,
Apr 23, 2:44pm
Autosol and lots of elbow grease
petermcg,
Apr 23, 2:47pm
Fine wet and dry sandpaper use with water.
mr2stiff,
Apr 23, 6:31pm
Pams oven cleaner, the one that works on a cold oven. Leave it on for 3-5 mins then polish off with scotch brite.
xs1100,
Apr 23, 6:42pm
autosol and elbow grease but only use a lttle bit at a time
jezz43,
Apr 23, 6:48pm
mothers mag polish. works awesome
morrisman1,
Apr 23, 7:05pm
some draino should do the job nicely
pdc1,
Apr 23, 8:06pm
bumping for someone to come up with the product name. I used to use something at an old work place. I guess it was an acid. Used to spray on with a sprayer and it would almost instantly take the oxide coating off and look like brand new again. No scrubing. Just a hose off.
monzaman,
Apr 23, 8:43pm
You might mean Pacer Products.
xs1100,
Apr 23, 9:22pm
car brite,pacer,shine car care,
i-n-horz,
Apr 23, 10:36pm
Once your've polished it back to life give the surface a good wipe down with meths this will remove any smudging,fine compound and used polish and she'll come up a pearl'a.
bigfatmat1,
Apr 24, 5:54am
alu-bright
ericshanluck,
Apr 24, 5:57am
+1 works well for galvanised steel too
big.b-lil.c,
Apr 24, 6:11am
best way to polish checker plate (that i have found) is autosol on a bit of carpet. that how i polish the checker plate on my truck.
mk3zephyr,
Apr 24, 6:17am
Shane, On my Saloon i tried a few products, tried Septone Aluminium cleaner from Supercheap and it worked ok but i see they have changed to 3M products now. Another one i tried was a product called Alu-Kleen from Tasman Chemicals in Auckland (basically mag wheel cleaner), Its a chemical so needs to be sprayed on. I gave the Aluminium a good scrub up and let it dry before using this product, certainly removed all the oxidation etc, you just have to play around with the dilution ratio to get one you are happy with, contains phosporous acid so wear protection when you use it. you spray it on, give it 3 or 4 minutes then hose it off.
candy1213,
Apr 24, 8:52pm
a good buff and auto cutter polish, then clean it off with meths, and clear paint it
redslapper,
Apr 25, 11:07am
i heard someone say that coke is good at it, don't quote me thou lol
bigfatmat1,
Apr 25, 11:18am
probly good at making it sticky
arerupdap,
Sep 12, 8:44am
http://www.sacmainlongchampfr.com
They're made the raised and greatest some terrific clothes. Another excellent profit of doing this clothing as a result of Ralph Lauren Uk the very fact may be purged but in addition covered. Their own designs do not ever destroy.Sac Longchamp Pas Cher
appoiftinorgo,
Sep 18, 10:52pm
??ossibly you could have viewed the million generate income Cheap nike nfl jerseysat this moment or maybe start off your own personal home-based business promotions http://www.dhmarkets.com/#rqfap all over the net when a person hop on the web. cheap nike nfl jerseys for china All these is going to quick look all of our curiosity for a little bit and then we only become shutter in their mind dhmarkets.com/#acwee as we clicked on each and every 4g iphone plus recognized each of them repeat the same task plus they many simply need a very important factor, our own bank or even debit card narodil selection.
raleplupgus,
Oct 3, 4:57pm
??ldi foods food store mn Answers
The Hollywood Walk of Fame stretches ??xrad Cheap nike nfl jerseys,
across the sidewalk from Hollywood Boulevard and Vine Street in Hollywood to La Brea Avenue. A lot more than 2,000 stars comprise the Walk of Fame, that was created in 1958. To start with, ww.nfljerseyoff.com/#zdx,
stars could receive multiple stars for separate performances, however nowadays the Walk does honor stars not previously on the Walk. Right now, generally two celebrities are awarded a star each month.
The Walk of Fame was designated a Historic Landmark in 1978, and a lot of tourists go to Walk of Fame annually to photograph the heavens ??wiev Cheap nike nfl jerseys,
with their favorite celebrities. The first star was awarded to to Joanne Woodward last month 9, 1960. Each star includes the name of the honoree in bronze www.nflnikejerseyforsale.com/#xke,
along with an emblem designating the medium which is why the celebrity has honored. The emblems add a video camer for film, Hdtv bewce cheap nfl jerseys,
for television, phonograph record for musicians, a microphone for radio and the comedy/tragedy masks for stage acting.
Recent construction about the Walk of Fame makes it needed to remove certain stars, which are being stored in ww.nfljerseyoff.com/#ptq,
an undisclosed location until they can be returned for their places on the Walk of Fame. Surveillance cameras keep an eye on the Walk of Fame, but such safety measures have never prevented thefts. Thus far, four stars have already been stolen, including the ones from Jimmy Stewart, Kirk Douglas, Gene Autry and Gregory Peck.
Stolen stars are already replaced, and repair off the Walk of Fame is undertaken by the Hollywood Historic Trust.The latest honoree was actor Roger Moore, who received his star on Oct. 11, 2007. Moore is better noted for starring in seven Jason bourne films from 1973 to 1985. Moore star, appropriately, is tak?
positioned at 7007 Hollywood Boulevard.
Preppy can be a term that is both a noun along with an adjective. Preppy term was in fact coined in case you attend prep school however today the meaning of Preppy is almost different.There are several tips which one can follow so that you can act as Preppy these tips are provided below: One appearance is paramount to act as Preppy. Wear designer and branded clothes like Mens polo shirt, Cable Sweaters, Sperry Top-Sider Shoes, Keds Shoes, Oxford Shirts since the mannequin within the store.
