The on-going saga
morrisman1, Apr 23, 12:32pm
Its a joke that people go on about how a n/a v8 would rape a n/a rice burner of 2L capacity. OF COURSE IT WILL! Its going to have over twice the capacity so naturally has a huge advantage there. By bringing up the 'take the turbo off and then see how well it goes' point all you are doing is admitting that yes the rice burner is fast and also acknowledging that there are multiple ways to increase power - the idea that you seem to be dead set against.
The v8 boys are starting to sound like little kiddies arguing over whose dad is tougher (well not all of them) and are becoming worse than the small capacity 4 cylinder fans themselves.
Its all good entertainment, I love a good fanboy battle!
jsbike, Apr 23, 12:41pm
for every 7psi you are doubling the air going in, and therfore the fuel. so a 2L turbo running @ 7psi in theory has a diplacement of 4L. how many 2L turbos running at a rather low 7psi would "rape" a 4L V8! I would have thought it would be quite even. Of course at 14psi+.-
savanna71, Apr 23, 12:57pm
pressure and volume are two differant things. naturally the flow of air from a little tdo5 at 7 pounds is completely differant from a gt3582r etc at 7 pounds hence why compressor maps exist
clark20, Apr 23, 1:00pm
No , wrong
1 bar is 14.7 psi, not 7psi. Less pumping efficiencies about 18psi would double torque.
sr2, Apr 23, 1:05pm
It??
morrisman1, Apr 23, 1:05pm
well power would be more accurately compared to in terms of air flow (ie in kgs per second or minute of whatever). If you have a really good flowing engine you can flow the same mass of air with less boost.
morrisman1, Apr 23, 1:07pm
That would take away all the fun!
sr2, Apr 23, 1:27pm
You're probibly right!
johnf_456, Apr 23, 1:35pm
Well said scotty is a good one for this.
mrfxit, Apr 23, 2:23pm
& that just the debates with petrol engines.
My poor old 2.4T Surf happily out tows a 2lt petrol n/a
That was with the 2l n/a petrol with 600kg's on the back of it's deck
My ol Surf with a 300kg trailer plus approx 1500kg on the trailer
Both Toyotas with 5 speed gearbox's of about the same age
gilligan2, Apr 23, 2:53pm
WHO CARES
joanie32, Apr 23, 5:31pm
Our boy ricer apprentice.40kand 5years on rb25 cefiro. Me 8k on xr8 boughtstraight off side of road. 5 litre factory car vs2.5"modified". Datsun didnt even come close.Hes now keen on swaps for any old V8 BTW
foxdonut, Apr 23, 5:39pm
What do you do in the cases of a 2 litre V8! or a 1.4 litre V8 turbo! Or a Turbo car that isn't Japanese! or a V8 that comes from Japan!
I just wish the munters on both sides would realise that "V8" is a meaningless term and the comparisons that are being made are shitty Australian sedan vs massively over worked shitty Japanese shopping trolley.
morrisman1, Apr 23, 6:47pm
mustn't have spent a cent on the engine
socram, Apr 23, 6:58pm
I'm with sr2.
There is more to any vehicle than just the engine. Drove a 1,000hp vehicle once.So boring.But, it would pull the skin off a rice pudding.Cornered as if on rails.Come to think of it, it was on rails.
joanie32, Apr 24, 6:46am
He spent thousands on mtr. three times. Its a really good case of too much $s and not enough clues.
wrong2, Apr 24, 3:42pm
well he obviously didnt spend $ 40 K on go-fast stuff did he if he cant beat a sub 400 hp ford falcon
