SparkPlug Gap
toycon, Apr 22, 11:01pm
Hi, I have a 90 Subaru Legacy sedan(non turbo.)
I took the plugs out to clean them and found that the gap was .042 th of an inch.
To my way of thinking this seems way to wide.
What do you think!
ginga4lyfe, Apr 22, 11:10pm
should normally be 1.1 Mm for newer cars ( apparently , and as such in your case )
ginga4lyfe, Apr 22, 11:12pm
Had a look through Auto data, and you should be at 0.8 mm
phillip.weston, Apr 23, 6:45am
I would go with anywhere between 0.7 and 1.0 mm.
intrade, Apr 23, 6:50am
well i know that my 1982 gti golf i once had has not liked it when the sparkplug gap was wrong by 0.2 only it cought spit and missfired. set it correct and woala ran mint. found it strange but true. thats late 1980s no irridium plugs back then
intrade, Nov 30, 1:01pm
having said all that places who sell sparkplugs can tell you what it needs to be usually they dont need to be changed as they are set to what most cars need from factory . especially the ones with 4 electrodes cant be set they are one off setting and thats what i usually fit to my petrol cars NGK -irridium. 75000km change intervall
http://www.ngksparkplugs.com/products/spark_plugs/iridiumix.asp#
you dont mess with the gap on these.
